Monitor size and Resolution - what is best size larger than 27"
HVAC-Novice
Advisor Advisor
Message 1 of 23
HVAC-Novice
We have the current Revit version and W10. i have two 27" (2560x1440) main monitors. I drop Revit on one monitor and place the panes (Properties, project browser) on the other monitor to get more Revit space. i also use a 3rd 24" HD monitor as a scratch place.
i don't really have multiple views visible at the same time (i.e. having a 3D view of the same thing i do in 2D) because the monitor is too small. More real estate would allow me to work better with that.
For my work in Revit I need PDF's open, Excel spreadsheets, browser  etc. So you imagine I'm juggling what I have open and that is before I have to deal with the "suddenly upcoming things" unrelated to Revit work. so I need more real estate. Good news is we are about to remodel our office, which could make us change things for the better with new electric moving-up/down desks etc.
My first idea was to buy a 4K 55" or 60" TV and split screen. Well, i tried that at home with a private 55" TV, and I was bothered by it being too tall while being close to the screen. Maybe that would work when being farther away from the screen. i also though the picture is a bit blurry when seeing letters. note i don't have Revit at home, so i couldn't test that properly.
My next idea are 32" 4K monitors. in W10 ( can scale each monitor, so the letters shouldn't be too small. they cost around $300-$400 each and buying 3 of them may be feasible. Or get 2 and reuse one of my 27" as parking space.
there also is the option to use 43" 4K monitors for maybe $500.
Another alternatives may be two ultrawide (21:9, 5K) screens. However, they seem to be much more expensive and I would have to check if my graphics card can handle them. and they probably would require
In an ideal world I would just try out each configuration for a few days. But in this world I kind of need to know what works best before I try.
Could anyone who made a similar transition or tested different monitor sizes what is the mot useful monitor size and configuration (no, the current 27" isn't... :-)? Please also add if you sit away from the monitors. Since we will get new office furniture, I may be able to get more than the 30" deep desk. whatever I buy now, I probably will have to live with for many years.
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
Replies (22)
Message 21 of 23
Portable display improves your work efficiency, and the convenience is beyond your imagination
Message 22 of 23
The portable display is so easy to use
Message 23 of 23
RobDraw
Swing and a miss.
Rob
