Modifying the Geometry of an Overlapping Roof
5 ANTWORTEN 5
Nachricht 1 von 6
653 Aufrufe, 5 Antworten
Good morning fine people of the Revit forum,
I've been trying to reproduce this overlapping roof, but can't figure out how to get the roof out of the way of the rear walls. The roof consists of one main section that runs the length the of the house at a 4/12 pitch, with four smaller sections that cover rooms that jut out from the main building.
I want to attach the walls to the roof, but in the back the main roof overlaps to cover the auxiliary roof. When I try to cut out a section of the main roof, the additional roofs detach and I lose my design.
Is there anyway I can cut the main roof to allow enough space for the walls to come up? At this point I'm not too concerned if its completely built out since I only need the model for elevations and floor plans. I've attached images that hope will be helpful in clarifying my inquiry. Thanks!
Original roof planOriginal roof planwhere the problem iswhere the problem isa wireframe viewa wireframe view
Revit version 2018.3, Version: 18.3.0.81, Number: 20180329_1100
Windows 10 Pro, Version: 1803, OS Build: 17134.345
Graphics card: NVIDIA GeForce GTX 1060 6GB
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
It would be easier to show you. Can you post your file.
...have you tried the Dormer Tool?
Nachricht 3 von 6
...another tip for you. Notice that not all the slope edges are defined in the pictured roof sketch.
Nachricht 4 von 6
Avaris.
Nachricht 5 von 6
als Antwort auf: barthbradley
Sure, and I'll try your first suggestion and accept it if it works.
Nachricht 6 von 6
FWIW: the back, right side gable roof is over-framed. In other words, it is built on top of the roof below it.  There is no other way to support it based on the current design.  You can model it in Revit to eliminate the portion of the lower roof that conflicts with your gable-end wall (using the dormer tool), but I don't see how it can be build that way.   Maybe I'm missing something.  Love to see your roof framing plans when your done.
