Modifying staircase stringer
Please see word doc and Revit model attached with my queries about modifying the stair stringer.
Appreciate any help.
Joe
Modify the PFC how? You mean change the End Cut (e.g. Vertical, Perpendicular, Horizontal)?
Hi @barthbradley , I've attached a word document to the original post with three queries I have.
- First query relates to changing the stringer type to a PFC member.
- Second; extending the stringer so it continuous beneath the landing; so it's a cranked beam.
- Third; extending the stringer down to top of the foundation which is 300mm below ground level; again adding a crank in the beam.
Sorry for the queries, but I'm rather a novice with Revit so would appreciate any help / pointers.
Joe
