Hi, is there any way possible that, can I make semi circle curtain wall/storefront (with mullions) instead of segmented? thanks
Gelöst! Gehe zur Lösung
Gelöst von planner_matlabi. Gehe zur Lösung
If you want true curved mullions then one option is using in-place sweeps, another is using adaptive components, or simply a window family.
thank you for your reply. are you kind enough to show me in video on how to do it.your help is much appreciated.
Watch Screen Cast
If it solves your problem, feel free to click Accept Solution.
hi, how can delete those extra panel, i tried but i cannot delete. thank you
thnak you, i cannot do that because of the different profile circle line of the lobby, if semicirle can. is there any other way to delete those extra panel?. i attached the profile of the lobby for curtain wall. maybe you could help me to create a curtain wall with that profile. thank you
@planner_matlabiplease ignore the first one i post. i attached the profile with door and the spacing for vertical mullion is 2m c/c. hope you could help me again. thanks
Hi
Excuse me for the delay in answering
I tried on your File
I hope your problem is solved
