Modifying & unlocking both wall finishing layers
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
anilcant96
607 Aufrufe, 5 Antworten
Hello everyone,
I'm having problem with modification on wall layers. When I unlock one side of the finish layer, lets say Finish 1, there is no problem with that I can off set layer from ground. However, when I try to unlock the bottom of the other side ( Finish 2) at first Revit gives error which I solved with opening the structure A.K.A wall layer too, sad news it now your ENTIRE WALL is unlocked so they come together while I was wanting somethink like below;
At this point I'm wondering why am I dealing with Revit and not going to work on with Archicad...
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: anilcant96
Unlock the Layers in the middle instead.
Nachricht 3 von 6
Create Parts. Activate Shape Handles and manually adjust.
Nachricht 4 von 6
Or, use ArchiCAD.  :zwinkerndes_Gesicht:
....what about separate Wall Types?  Too difficult?  Yeah, maybe ArchiCAD is the best solution.  Good luck.
Nachricht 5 von 6
Several ways aside from what suggested:
- If you have three floors (structural floor to attach the core, an exterior finish floor, an interior finish floor), then you can attach the wall to all three.
- Use reveals
Nachricht 6 von 6
anilcant96
als Antwort auf: barthbradley
It is quite challenging software for beginners like me, a lot of people around me says that why am I trying to get on with Revit and not move to other softwares. However, with that answer I've got one more plus day to continue with Revit :leicht_lächelndes_Gesicht:
