We're wanting to alter params on a titleblock from the sheets properties panel.
We've been successful in adding a label to the titleblock, setting up a shared param for it, adding that shared param to the project (tied to sheets) and then we can see that param under the sheet properties and it will change in the titleblock. Works great. Here's where things get trickier...
What we're trying to do is control the visibility of items via instance params (architectural stamps, in this case).
We added new shared params, then added those to the params list in the titleblock family. The objects' visibility is tied to them, no problem.
We added the same shared params to the sheets in the project.
When we click on a sheet in the project, the params show, but they do not affect the status of the same params on the titleblock. If I select the titleblock, I can alter the params there, but changing them on the sheet level does nothing. In fact, by default the params are all grayed out on the sheet properties.
The goal is to be able to select multiple sheets and change these params instead of having to open each sheet, select the titleblock, change the params, rinse and repeat.
Any idea if what we're trying to do is possible. It seems like we're so close!
Thanks!
Matt
