Modify the floor hole edge thickness
2 ANTWORTEN 2
Nachricht 1 von 3
JML_Mela
307 Aufrufe, 2 Antworten
Hi!
I am getting crazy trying to fix this issue:
I have a family (there will be a lot) hosted on a floor. This family is a metal box and i would like it to be seen as in the attachement thin, with the edges of the floor also thin, without using LW (there are a lot of them).
Is there any automatic way to do it?
I have been testing with Floors subcategories (Common Edges, Interior Edges, Slab edges), Cut Line Styles... Bu anything has work.
Could you please provide some light?
Thank you!
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: JML_Mela
The last one in you pic?  Nest a detail component with a filled region in the family, slightly wider than the void, to mask the flood edge.  If you are using 2023, you can add the filled region directly in the model family without nesting a detail family.
Nachricht 3 von 3
JML_Mela
als Antwort auf: ToanDN
Thank you!!!!
My intention was to avoid the detail families, but it seems to be the only way :leicht_lächelndes_Gesicht:
