Modify Sub Elements - Floor - add point on edges?
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
paryseVSJ9U
287 Aufrufe, 2 Antworten
trying to get my garage concrete slab to slope towards the garage door opening, is there any way to add point right on the edge of the floor boundary? so it slopes towards the middle point of one edge of the floor?
2 ANTWORTEN 2
Nachricht 2 von 3
jay_colcombe
als Antwort auf: paryseVSJ9U
If you draw a flat slab/floor you can use the Shape Editing Panel to Modify Sub Elements to achieve said slope.  simply Add a Point to the edge in question and select it and edit the 0 value to a - value
You can also add slope arrows
Jay Colcombe
Autodesk Certified Instructor
Nachricht 3 von 3
paryseVSJ9U
als Antwort auf: jay_colcombe
Ok great worked out! somehow at first it wouldn't let me place a point right on the edge of the slab, and was doing weird geometry, but worked out now! thanks for the help! learned a new trick.
