Is there a way to modify sub-elements for a ceiling like you can do for a floor or roof? The floor below is done with one element with split lines, but the ceiling needs 3 pieces, the 2 sides using slope arrows.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Use a floor or roof for your ceiling. It's done all the time.
BTW: you can slope a ceiling. Are you aware of this? The ceiling has a Slope tool you can use for this.
Hi !
While sketching the ceiling use the slope arrow tool as used for the floor.
You have to sketch 3 ceilings. First part with slope arrow from the right side to the left, middlepart without arrow, left part with arrow from the left to the right side.
Kind regards,
Bernhard
3c6739b0-6f7c-4218-9952-db9542b8f114
