Modify Sub Elements - Ceiling
PhilvK
Advisor Advisor
PhilvK
Is there a way to modify sub-elements for a ceiling like you can do for a floor or roof? The floor below is done with one element with split lines, but the ceiling needs 3 pieces, the 2 sides using slope arrows.
Use a floor or roof for your ceiling.  It's done all the time.
BTW: you can slope a ceiling. Are you aware of this?  The ceiling has a Slope tool you can use for this.
B.Fetzer
Hi !
While sketching the ceiling use the slope arrow tool as used for the floor.
You have to sketch 3 ceilings. First part with slope arrow from the right side to the left, middlepart without arrow, left part with arrow from the left to the right side.
Kind regards,
Bernhard
Screencast wird nach Klicken auf „Veröffentlichen“ hier angezeigt.
3c6739b0-6f7c-4218-9952-db9542b8f114
PhilvK
Yes, that's the way I did it for the ceiling. i.e., 3 pieces. The floor was
done with one element with split lines, and modifying sub element
elevations, which is what I was hoping to be able to do with ceilings.
