Hello everyone,
Hope you can help me with this one:
I created a stacked wall with two different sections and place it as a facade, t'ill here no problem. Now i deed the stacked line division to follow a certain RP.
¿Is there any way we can change the division line from a horizontal line to a custom line?
Many thanks
Unfortunately, no. Stacked Walls are divided only by horizontal edges.
A workaround to look into would be to place "Base Wall" and "Top Wall" source wall types individually and use Edit Profile to adjust the top/bottom of each. Luckily you can use your Reference Plane as a sketch line in sketch mode.
Unstack it (break up), draw the ref plane in the elevation and attach the top of the lower wall and the bottom of the upper wall to it.
