Modify slope of roof
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
1390 Aufrufe, 2 Antworten
I need to enter value of slope  for roof under the title of Dimension in Properties palette. But slope field is disabled. My question is that how can I enable Dimension and enter value for slope. Button Apply also needs to be activated (enabled). I shall be grateful if someone could give the solution.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
You need to select an edge and check the box 'define slope'. Then you can
enter the slope value.
Nachricht 3 von 3
als Antwort auf: ToanDN
Thank you . It has worked
