Modify revit family
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
chrisR3P9C
633 Aufrufe, 1 Antwort
Modify revit family
I'm trying to modify a counter top .rfa file.  Specifically, I'm trying to add a 45 degree taper to one end.  I've managed to "edit family" and create the shape I want.  However, when I load it into the project, only the thumbnail of the counter top in properties window has changed... the actual component/object remains unchanged.  I've attached an image to help explain.
What am I missing?  Thanks in advance!!
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: chrisR3P9C
Did you go to Plan View in the Family and change the shape of the Masking Region as well?
...Or, get rid of the Masking Region, if one exists, and select the Countertop Geometry, open its Visibility Settings and  check Plan/RCP.
