trying to modify a notekey. txt to adda tag in notekey.
I don't try correct correspondence between symbol and Text.
If tag a windows show me both of them.
Thank's
Gelöst! Gehe zur Lösung
Heva to select correct space between character.
Solved
Hi @Anonymous
HERE is some additional information on adding custom keynotes in design documents.
Also, see Text Note Type Properties
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
