Modify IFC format on Revit
5 ANTWORTEN 5
Nachricht 1 von 6
8325 Aufrufe, 5 Antworten
I'm currently writing my final work and in this context I'm working on Revit. I have a file in IFC format and I bind it Revit. But I do not know how to change it. Is it possible to modify elements of an IFC file? And how?
Thanks for yous hepl, you are my last chance.
Natacha
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
You cannot change the geometry of any IFC elements.  You can change phase and other parameter value.
Nachricht 3 von 6
als Antwort auf: ToanDN
Thank you very much.
But how does one select an item, for example a wall? I do know that select the whole model and not the elements separately.
Thanks for your help.
Nachricht 4 von 6
If you bind it in your Revit file, it should become a group. Edit the group and you can edit individual elements.
Nachricht 5 von 6
ryan
If you open the file via the way illustrated below, you can modify the geometry.   There are a few exceptions however.
Nachricht 6 von 6
Hello, I am currently writing my thesis, focusing on BIM and Facility Management. Everything looks nice and surely the bim can be used as a valid tool to manage a building, but I'm having some doubts ..
If the whole project is delivered to the building manager in the ifc file, how can the manager modify, for example, a wall in the project if it is demolished in the building? How can the manager modify the geometry of the project as the real building changes during its life cycle?thanks.
