Modify Hidden Line Style for Top Railing & Hand Rails
4 ANTWORTEN 4
Nachricht 1 von 5
BigPicture045
283 Aufrufe, 4 Antworten
How do I change the hidden line style for the top rail and hand rail part of the railing? I only see the <Hidden Lines> which I can change but this does not affect the top rail or hand rail. Consequently, my railing and these other two parts have different hidden line styles.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: BigPicture045
Nachricht 3 von 5
BigPicture045
als Antwort auf: barthbradley
What you have shown is not hidden lines style that is revealed when the railing is hidden behind a wall. See in the reference below how my railing and handrails have different style of hidden lines:
The railing is the lower highlight and the handrail is the upper highlight. I can only adjust the railing hidden lines from the graphics but I do not see how to edit the handrail when they are hidden.
Nachricht 4 von 5
I suspect there is another override acting on the elements.  Maybe Phase Filter Graphic Override?  Can you override graphics via Override Graphics in View BY ELEMENT?
Nachricht 5 von 5
Have you adjusted the Far Clip Distance to remove one of the two Railings from the View?  Maybe you are looking at overlapping Railings.
