I have a simple floor and wall above.
If modify the floor say me "Modify height of wall selected till lower part of floor".
Is a warning that have to put on attention?
Have to attached wall to floor of level underneath (level -1)?
Thank's
Gelöst! Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
@Anonymous hello, just change your all lower floor to top constraint unconnected and it will be fine. thanks
@Anonymous hello, sorry i forget to attach the file, you may check the file attached. i dont receive any error message and compare your original files. thanks
@Anonymous hello, if is still not working, try to pick the lower walls and go to detach top/base and pick the slab. change the top constraint to unconnected 2.8m and it will work fine. let me know if you dont get it. i will do a screencast video for you. thanks
