Modify Ceiling Grid Pattern
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
PhilvK
1994 Aufrufe, 2 Antworten
I have an existing 2x4 acoustical ceiling where additional grids have been added in some sporadic areas to make it 2x2. It's a small area and I can handle it with detail lines, but is there a way to edit the pattern within the ceiling so it still acts as one element?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: PhilvK
You can split face and paint with 2x2 material.
Nachricht 3 von 3
Clipboard Copy/Paste Ceiling to same Place, change the Material of Copy, and then edit both ceilings' sketch boundaries.
TIP: Use Pick Lines Tool.
2 Ceilings:
Benefit is in the more accurate scheduling.
