Modify all Grid Bubbles on all sheets automatically
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
4531 Aufrufe, 6 Antworten
 I would like to modify the grid bubbles on the sheets, but I want to do it once and have Revit apply my choice to all the sheets in stead of having to do it sheet by sheet since I have a lot of sheets. Any Ideas? Thanks!
Tags (2)
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
Nachricht 3 von 7
Sahay_R
Create grid bubble families - or family types. Select all in project and then you can switch them out instantly.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 4 von 7
als Antwort auf: Sahay_R
Grid Bubbles are come from the Views -- not the Sheet. So you would need "Pre-Set" Views already on the Sheet (as well as in the Project).  That's the way I was reading it.
Nachricht 5 von 7
mkarr
Similarly, is there a way to copy grid bubble offsets from floor to floor if you have grids at very tight spacing? Or if not, are there any plans to implement this? I'm glad it's not automatically forced but having the option would be awesome.
Nachricht 6 von 7
als Antwort auf: mkarr
Nachricht 7 von 7
mkarr
als Antwort auf: ToanDN
Yep, right there in front of my face. Thank you.
