modify a concrete slab floor to wood joist floor
3 ANTWORTEN 3
Nachricht 1 von 4
Smunir30
299 Aufrufe, 3 Antworten
Hi:
I am a student and accidentally I did a floor with concrete slab. Need to delete that and make it as wood joist floor. Please help
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Smunir30
Select the existing Floor then click inside the Properties Pallet Type Selector (where the thumbnail is displayed) to open the drop-down list. Scroll up/down to find and select the Floor Type you want to replace the existing Floor with.
Nachricht 3 von 4
eizinmyat
Could you try with this way?
Click the existing floor and at the properties panel, choose the material type that you want from the dropdown list.  If there is no material, you can edit type and at structure, you can edit the structure of the wall. Click the material and choose the wood from the material browser. I attached the video so that you could watch it. I hope it helps you.
Ei Zin Myat
Technical Sales Unit Engineer
ONESTRUCTION Co., Ltd.
eizinmyat@onestruction.com
Nachricht 4 von 4
jay_colcombe
As previously mention you can edit the Floor build-up to replicate a timber joist Floor construction
However, you cannot convert a Floor Slab to individual Floor Joists/Members you would need to create Beams or Beam Systems for this
Jay Colcombe
Autodesk Certified Instructor
