Hello everyone
We started to model Droneport (Norman Foster) in Grasshopper but we had a problem in materializing it.
Then we decided to import the model into Dynamo but we failed. How is it possible to import Grasshopper to Dynamo to not identified as a generic model? We want to use bricks as the main material and cover it with cement but we couldn't find the right way to place the bricks properly on this surface and control those bricks.
It would be nice if anyone could help us through this process and writing scripts.
Thanks in advance,
Fatemeh
https://drive.google.com/file/d/1kIpUHilpy-Jb0XbmR2OFFoCK5FkQu1a7/view?usp=drive_link
This can be modeled using the adaptive template, because that template has the tools to make surfaces. Once you have surfaces, you can load the family into a project and then use either Wall by Face or Roof by Face, with materials such as brick or concrete. I can't help with the other part of the question (Grasshopper into Dynamo then into Revit to materialize). All I know is that this can be modeled without using those tools, just Revit families.
