I have some relatively simple walls I need to create throughout my project, however their shapes are slightly irregular and I want the interior to be part of the wall as an air cavity (rather than a single leaf of brickwork drawn along the perimeter)
The below screenshot is 3 separate walls of varying thickness with a brick leaf on either side, can anyone advise how I'd model these such that the outer leaf joins continuously around the outside?
I've attached a model too containing just these 3 walls.
Thanks!
Yeah I need brick on all outward faces and an air cavity inside (so we can potentially change the color of the filler etc), if that makes sense.
The irregular shape arises because we have concrete columns ( a linked model) positioned inside, which I need to wrap brick around. They would otherwise just be normal walls / corner of walls.
If that is the case then I would model the brick veneer as thin brick walls wrapping around the shape.
I think that might be the best option, I just suspect I might need to edit the interior fill of these walls at some point, in order to change the cut color, to NBS tag them etc, in which case it'd be useful if the interior is part of the wall itself.
I imagine it's going to be difficult to get it to work as I'm currently trying? It's currently 3 pieces of wall of varying thickness in that screenshot, but i just can't get it to wrap that last bit between the 2 adjacent pieces of wall.
The only other option I can think of is to use your wall type with the brick set to have wrapping at ends on and then embed architectural columns into the wall of the varying sizes to get the shape you want.
Architectural columns in walls act as piers and will have the finish layer of the wall wrap around the column.
If you then set the core wall material and the column material the same it will all look like one.
