Modelling an Arch
Modelling an Arch
tonkata
Modelling an Arch
tonkata
I am trying to replicate this arch modelled in Sketchup, over here in Revit.
I have NO idea how to go about this, can someone please help?
You can model it with an arched opening then a void sweep picking the edges of the opening to create the chamfer.
I realized the chamfer is not with a consistent profile so you cannot use a void sweep.
Create it using a void blend with two profiles.
Here is a family that you can place in a wall in the project to cut the opening.  You can change any parameters to give you the dimensions you want.
tonkata
@ToanDN, praise your cotton sole  🙏 this is perfect, though I'm still on R21, any chance you can re-save the family as a 21 version?
tonkata
@ToanDN or are you able to record a quick tutorial on how you when about it?
tonkata
@ToanDN THANK YOU SOOOOO MUCH 🙏
