How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Hello community,
i have a problem with the correct display of my model (created with Revit 2019.2.). The model is always a wireframe model, even if I change e.g. the image style to realistic. Also, the borders of the elements are strange and I cannot zoom-in anymore. Has anyone had this problem before or maybe a solution to this problem?
Do you have any particularly large DWGs linked in? I have had the wireframe issue with pesky DWGs before. Remove them and see if that helps.
have you check phases? Maybe you have phase filter override.
If yes, select "Show Complete" phase filter.
i tried to remove all linked docs and it is not helping
it is not helping, the behaviour of Revit does not look normal. It feels more like a bug.
Can you confirm if it's only one view that displays as wireframe? If so, it could be that the view is corrupted, in whicj case, make a new one. As previously mentioned, it caould be DWG that has extents far from the origin. You mau have removed linked DWGs, but it may have been imported. Try to switch off imports in the view to see if that resolves the issue.
Is it all views, or just the one?
Did you try to switch off Imports in the view?
Try going to a plan view and turning off the crop. Zoom to extents to see if there is some element that is far from the origin (your elements will disappear as they will be too small to see). If so, remove it.
Post the file. We'll examine.
Is the document that I sent you on Email working?
https://www.dropbox.com/sh/tiur4t7qd68s7gb/AADIu9Xe3MUfWsFT2qojFuiUa?dl=0
here is a direct link to dropbox in case the first one did not work.
Did you try the steps that I suggested?
There is a red line that is about 33 000km from your origin. Find and delete it and the file displays correctly.
model is working for me. Revit 2019
I see it in wireframe too.
And also, when I zoom out, model is huge. There is something far far away from the model making this view huge.
I did exactly what you said, but until now I can't see any element other than the model
So it is fixed now?
If not, the offending item is called FIDES_Trasse, which is a family.
@Anonymous wrote:So it is fixed now?
I agree, the problem lies in the FIDES_Trasse (Rampe1).rfa family.
If you delete it, model works fine.
I suggest recreating this family with DWG which has no elements so far away from the origin.
How to buy
Type a product name
