Greetings,
I am trying to create a site using the option Toposurface> add points.
I am having trouble finding out how to manage the exact form the surface takes. I have added a screenshot of three different surfaces(This is what i want the surface to look like). When you merge these together, revit combines points that i dont want to be combined(black lines).
Am i using the wrong option or how should i model this surface?
Thanks in advance!
Gelöst! Gehe zur Lösung
Gelöst von Corsten.Au. Gehe zur Lösung
Toposurface? I don't see a Toposurface in your screenshot. Can you provide a orthographic view?
...maybe you mean you are trying to create a form?
You can use " Split Topo " to achieve that result..
or
Ah yes, this is exactly what i was looking for.
My apoligies for the vague description, i did not know you can use split surface for and then delete the parts you dont want to connect to eachother.
Thanks a lot!
