Greetings,
I am trying to create a site using the option Toposurface> add points.
I am having trouble finding out how to manage the exact form the surface takes. I have added a screenshot of three different surfaces(This is what i want the surface to look like). When you merge these together, revit combines points that i dont want to be combined(black lines).
Am i using the wrong option or how should i model this surface?
Thanks in advance!
Afternoon! hopefully I've interpreted your request correctly.. your trying to get the topo surface to form the darker shape however its connecting corner to corner? (the black lines your referring to)
One option would be to use the split surface tool to remove the sections of the topo surface and trim it back to the desired shape, I've attached a few screen grabs of the kind of thing i mean. You'd have to do this a few times as the split surface will only let you divide the surface into two at any one time.
