Modeling on Point Cloud
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
FarhanUddinShaikh
508 Aufrufe, 3 Antworten
Please can anyone guide about how we can model on point cloud in Revit? i-e any type of script ? how we can modeled perfectly on levels etc, any kind of example would be helpful!
Thank You,
3 ANTWORTEN 3
Nachricht 2 von 4
PrathapSekar
als Antwort auf: FarhanUddinShaikh
Hi @FarhanUddinShaikh!!!
A third party software named "EdgeWise" is there to capture the elements on point cloud in some clicks.
Else u can do thinks on Revit itself, as fallowes
  • Get a Revit template / prepare yourself a template comprises coordination, true north and other thinks.
  • Load your point cloud file into it, check it sits correctly.
  • Take a section across your pontcloud and create the required levels/ modify existing as you required.
  • Start modeling, draw walls and other thinks over the pointcloud.
  • check the elements matching by taking sections / elevations, and 3D section box view.
Hope this brief may help you. you can find so many videos in we surfing.
Feel free to ask for more details. Thanks.
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
Nachricht 3 von 4
cbcarch
You might check into this:
http://www.clearedge3d.com/
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 4 von 4
FarhanUddinShaikh
als Antwort auf: PrathapSekar
