I have an upcoming project where each wall is made up of a series of different shape/ different angle panels. I have been experimenting with different ways to model including associating the panel to a reference plane but then the panels don't connect correctly. Is their a way to put a floor at a vertical angle in revit, I believe that if I could modify sub elements at a vertical plane it would solve my problem? If you were given this task how would you model it?
Gelöst! Gehe zur Lösung
Gelöst von cbcarch. Gehe zur Lösung
A few methods could work:
1. Conceptual Massing with panels applied by Face.
Might need Adaptive Components--http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-6E0ECA27-AF40-4B1D-9E0B-1DE5FBBD45F2
2. Roofs with edited points
3. Ceilings with slope arrows
