Hello
as the title suggests, i have a bridge that i want to model, i just want to model it, dont need the rebar or to do sturctural analysis on it, i have the cross-section of the bridge, and the coordinates of the center line of the bridge (x,y and z). could someone help me. and if revit is not the optimum program to do so, what is?
Thanks in advance
Too generic question, please elaborate. Add images/sketches/the cross-section etc... Yes, you can model it in Revit.
That's a super generic question
hence my reply will be equally generic
Et voila...
Normally I would have elaborated more; however, when I see a user posting same question on several Revit Forums and/or a user who rarely marks a solution, I tend to be a little bit reluctant … not too generic yet not too elaborative ![]()
thanks for your replies
so sorry for duplicating the post, didnt know where to post so i tried both.
ill try the method suggested, seems manageable. thank you for your solution.
again sorry for duplicating the post
So, you fault someone for networking and judge them by solutions marked?
I evaluate the effort I should put in drafting a reply and not fault that someone...Help offered is relative
And I thank you for that.
