model visibility issues
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
576 Aufrufe, 10 Antworten
I'm having weird visibility issues in a model that I've inherited, and I can't figure out the issue.  Items that are embedded in the wall as well as behind the wall and not even touching it are showing up, where normally they wouldn't be visible.  It's happening in 3d and elevations.  See attached image.  Any ideas what's going on?  I've checked element and material transparencies, I'm in shaded w/ edges visual style.  Phase filter is set to show complete, new construction.
10 ANTWORTEN 10
Nachricht 2 von 11
dferreira-blackwell
als Antwort auf: Anonymous
set phase filter to show all, see if any filters applied through vv/vg. check the discipline.
Nachricht 3 von 11
als Antwort auf: dferreira-blackwell
nothing odd there, got anything else?
Nachricht 4 von 11
dferreira-blackwell
update your graphics driver through windows. Or create new view for quick result.
Nachricht 5 von 11
bin
This 3D view is corrupted, delete it and create a new one.
Nachricht 6 von 11
graphics driver isn't the issue.  the same quirks show up on another fairly new computer.  also, other much more complicated revit files don't have this issue.  creating a new view doesn't fix it either :enttäuschtes_Gesicht:
Nachricht 7 von 11
als Antwort auf: bin
i wish it were that easy!  it shows up in elevations too.  creating new views from scratch doesn't help the problem either.
Nachricht 8 von 11
bin
can You share the file so we can have a look?
Nachricht 9 von 11
Turn off CAD links/Imports.
Nachricht 10 von 11
als Antwort auf: ToanDN
YES!  THAT DID IT!  I never would have thought of that.  Thank you so much, @ToanDN !  I've never come across that before, what was it that was showing up?  3d DWG lines?
Nachricht 11 von 11
Did you link the CAD file directly in the model or in a model in place mass or in place family?
