I need this signage to be curved along this roof face. I am trying to get the text to host to a curved wall to achieve this - as stated in this thread from 2016:
Solved: Placing Model Text on Curved Walls - Autodesk Community - Revit Products
I am not getting the same results, was this feature removed?
Does anyone have a family for this? All other solutions appear quite complex.
I
If you only have a few letters then create a letter as a face based family with an instance parameter to change the letter content, load in the project and host on the curved surface one by one.
If you have a lot, then create parametric family for a letter, nest in a adaptive family's divided line nods and associate the parameter so you can change the content for each letter.
Not following this part:
" nest in a adaptive family's divided line nods"
Use a Radial Array to array a single letter then edit each letter and change it to the right letter.
