Model Text is a Generic Model but a Window
ridantuo
ridantuo
Hello.
So this came up in a Revit file yesterday:
It is not an issue in it's self as I can just redo these/change the family from dropdown (there are 2 and both are window families 😁), but if there are more similar things hiding it will make a dent into the data quality. Luckily as it is still a Generic Model like Model Text it doesn't hop into the Window Schedule.
I'll try to keep an eye out and figure out what caused this. Has anyone else bumped into this kind of an error where something that is supposed to be something identifies as something else on it's own? 😁
Things I tested first:
Rehosting the Model Text
Copy/Pasting to same place
Changing the Work Plane
This model did go to Autodesk to get a fix to the Schema Conflict issue, so this might relate to that.
Added screenshots from RevitLookup as attachment.
PICNIC: Problem In Chair Not In Computer.
Around 90% of issues can be explained by human error instead of an actual error.
Simon_Weel
Can you post the Family?
ridantuo
Nothing special about the window family that I've seen.
Mike.FORM
So what is the issue? The window family is showing fine to me in project.
Are you just saying you have a generic model - model text family and it is showing the window thumbnail?
Recategorize the Family
ridantuo
I think it was just this bug in the end as everything seemed to be fine in the central and family file. So it showed the thumbnail and the info of the window family for some reason, but all the rest was from the model text component.
Still would like to know how it happened but maybe it was the repair?
ennujozlagam
it was a window family?
try to install latest updates from autodesk and see if helps?
