Model template file does not open
1 ANTWORT 1
Nachricht 1 von 2
275 Aufrufe, 1 Antwort
Hi Community,
I have a new laptop and recently installed Revit. The first time wifi connectivity issues occured and the installation process was stopped. After that I successfully downloaded Revit and it works. The problem appears once I want to open a template file for a model. The file is installed on the laptop and I can select it, but after that it only loads halfway through and after that for forever. It doesn't open completely and I can't even close Revit in the meantime. I already tried deleting and reinstalling Revit three times, but the same problem arises nonetheless.
I would be so grateful if somebody could help me with this issue.
Beschriftungen (1)
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
Perform a clean uninstallation of Revit then reinstall it from fresh.
https://knowledge.autodesk.com/support/revit/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-C...
