Hi, I am architecture student , recently i face one big problem is Model shows as Wireframe in non-Wireframe views in Revit, no matter what view i changed but still remain the same. VV checked, Hidden Lines checked, Eye elvations allso checked , but still same can someone save my project , I'm using revit 2020 version student and my furniture all is download by revit city . Coarse, Fine, Medium views all tried.
someone pls help me !!! thank you
Gelöst! Gehe zur Lösung
Gelöst von LiewYingJie. Gehe zur Lösung
Check if you have any Cad Imports or Links which have their Origin very far away ( more than 20 miles) from Revit's internal origin. This can cause odd graphics behavior.
Also check your graphics card/driver to see if it is up to date/approved for Revit by Autodesk.
HI, THANKS FOR REPLYING , but how to check Cad Imports or Links which have their Origin very far away from the revit origin ?
Imported Cad:
Type VG>Imported Categories. See if there are any Cad file.
Linked Cad: Go to Manage Links>Cad Formats.
Check Imports in Families in VG.
Any Cad file in these locations could be the problem.
You would need to find the Cad file, Open it in AutoCad, and move the Origin closer to the center of the drawing and reload it into Revit.
You can check Linked model from Manage >>> Manage Links
Unload any suspicious links and try if that fix it
Alternatively try to disable Use Hardware Acceleration (File >> Options >> Hardware)
Check you eye and target elevation and see if there is a huge number. If it has, then what you need to do is click on the view cube isometric corner
It will reset back to normal view.
HI , Guys thanks for helping me is my cad file problem because i using import cad and my file too big so it likes affected.So i deletd my cad file everythings alright .
THANK YOU , I APPRECIATE YOU GUYS.
hi my name is juwon
Can I know the reason why I should change the target level in this solution?
