Model showing up on electrical plan instead of annotation
20 ANTWORTEN 20
GELÖST
Nachricht 1 von 21
tommy.adams6R4JL
1373 Aufrufe, 20 Antworten
Usually when I place a lighting fixture family into Revit, it will show up in 3D but only the annotation symbol will show up on my electrical plan. I downloaded a new lighting fixture family but for some reason the model is showing up in my electrical plan instead of the annotation. Any ideas? Thanks!
20 ANTWORTEN 20
Nachricht 2 von 21
als Antwort auf: tommy.adams6R4JL
Change the Visibility Settings of the Model Geometry in the Family. Sounds like you want it to be hidden in Plan/RCP.  Uncheck the box then.
Nachricht 3 von 21
tommy.adams6R4JL
als Antwort auf: barthbradley
The box is unchecked but it still shows up.
Nachricht 4 von 21
RDAOU
The Geometry/ extrusions in the family are set to show in plan/rcp
Edit >> select extrusion >> visibility settings >>> uncheck plan/rcp
Nachricht 5 von 21
Sounds like a 2D Representation then.  Go to Plan View in the Family and see what's there. Maybe a Masking Region?
TIP: Toggle the Preview Visibility ON.
Nachricht 6 von 21
tommy.adams6R4JL
als Antwort auf: RDAOU
I tried this and the box is unchecked but it still shows up.
Nachricht 7 von 21
RSomppi
Share the family.
Nachricht 8 von 21
tommy.adams6R4JL
als Antwort auf: RSomppi
Here is the family in question. I hope you find it helpful.
Nachricht 9 von 21
How are you placing it? On vertical face, face or workplane?
Vertical Face Representation:
Face and Workplane Representation:
Nachricht 10 von 21
tommy.adams6R4JL
I am placing in on a vertical face
Nachricht 11 von 21
tommy.adams6R4JL
It looks like this may have been the issue. How do I get it to show the annotation symbol in vertical face representation?
Nachricht 12 von 21
Vertical Face? Then you are seeing 2D Masking Regions that are in the Family.
Nachricht 13 von 21
You can't. Tag it in the Project instead.
Nachricht 14 von 21
tommy.adams6R4JL
I am unsure what you mean. I'm pretty new to making revit families. None of my other light fixtures give me an option for a plane to attach it to. They automatically snap to my walls and place an annotation symbol when I place them. I dont know why this particular model is giving me a different set of options when placing it in the project.
Nachricht 15 von 21
Because it is a face based family so you have more options to choose to host it.  The one you had is a wall base family so it always choose a wall as the host.
Nachricht 16 von 21
tommy.adams6R4JL
als Antwort auf: ToanDN
That makes sense! So theres no way to change it from a face based family to a wall based family?
Nachricht 17 von 21
There are.  However,
1 - it is unnecessary.  A face based family can be more flexible in a lot of conditions.
2 - it may not address your original question.
So, share the family here so we can look at it and suggest suitable approaches.
Nachricht 18 von 21
tommy.adams6R4JL
I'm needing to change it to wall based so it is consistent with our other lighting fixtures. I dont see myself placing these lights on anything other than a wall. I've attached the family. Thanks!
Nachricht 19 von 21
Why don't you just place it on a Workplane?
Nachricht 20 von 21
tommy.adams6R4JL
I mean we can but we want our library of families to be consistent. Every other lighting fixture we have is wall hosted so it would be great if we could make this one wall hosted too.
