I am trying to create a check with Model Review that reports back the project basepoint and the project survey point.
If both are at 0,0,0 it passes. If anything returns other than 0,0,0 it fails.
Scrolling through the lists of checks, I don't see anything that does this. It's all based on selecting an element to obtain parameters. What is the trick?
No similar method is available.
You will need to select them or use the below tool or use spot coordinates and elevation annotations.
Mostafa Elashmawy
I know how to display it manually. I want to run a standards checker (Revit Model Review) that will report the base and survey points, along with a bunch of other checks, from multiple models.
Note: This review check can be done using the BIM Interoperability Tools. I do not want to use one add-in for some checking, and another add-in for other checking.
Looking at it from the other direction (because I really know very little about Model Review) what checks can you NOT do in Model Checker?
