Hello Everyone!
Recently I have run into a problem, where when I link the Architectural and MEP models together with "Origin to Origin" option, they show up as intended.
But when I export them to IFC, they are 650 km apart from each other.
What is the solution for this?
All right! I moved the Survey Point and it solved the dislocation problem, but I still need to rotate it. Is it possible somehow?
In Revit, you can:
- Setup True North and Project North, and specify the angle between them. This essentially rotates the project, depending on whether the View is set to True North or Project North. Manage Tab>Project Location>Position
-Specify coordinates at Point
-Publish Coordinates
-Aquire Coordinates in the Linked Model from the Host.
