I have created a detail item with a model line hatch which is 2mm apart. This should not be possible in revit? I dont know how i created this so perhaps someone can try to figure it out?
What i want is to upgrade this hatch (lines_test) to a plywood version but the parallel lines cant go closer then 50mm.
The detail item is attached.
