AnzeigenĀ Ā nurĀ  | Stattdessen suchen nachĀ
Meintest du:Ā
Model Lines x Symbolic Lines Visibility
2 ANTWORTEN 2
Nachricht 1 von 3
thebimqueen
169 Aufrufe, 2 Antworten
Hey guys I am having some issues with my lines showing behind my object in my plan view. What I would like to happen is that my lines (some SYMBOLIC // MODEL lines) would not appear behind object on top of them, in thus case my structural column. I want these lines to not appear behind my object but the only way I found out how to do this is to turn off these layers (which I don“t want to do because I want them to show if there are no objects covering them).
Thanks!
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: thebimqueen
You can place detail linework in a Model Family on a Ref. Plane Work Plane that is below the Detail Plane.  You do this by unchecking Draw in Foreground.
More about it here:
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Revit-D...
Nachricht 3 von 3
Post your Family here if you are having difficulties.
In Foren verƶffentlichen
