Model Lines not staying locked
therevitsith
therevitsith
I've built this grid family to help with layouts, etc., but I can't get the model lines in the arrays to stay locked to any length constraint for the life of me. Any help is greatly appreciated!
Replies (8)
How it this to be used?  Walk me through a workflow that uses it.
Regarding your issue:
Create the element that you want to Array in a separate Family and nest it into the Family that does Arraying.  Use Instance Parameters to parametrically drive its Length and Associate that Length Parameter to a Length Parameter in the Array Family that it is nested into. Also, make sure the Line lengthens in one direction - not outward from the middle.  Align and Lock the beginning of the Line to a Pinned Origin Reference Plane.
See if the attached Family helps.
therevitsith
I want to place this to align walls, doors, windows etc. Think of it as a piece of grid paper. I want to use it early in a project to set a module. To be able to set the grid at 3'4 or whatever and have the entire thing change when I change the grid size.
So you're saying I have to have the arrayed model lines as their own family? Just seems crazy that I can't do that in the same family. I have the beginning of the line locked to the origin reference plane and a length constraint tied to it and it works fine but it's when I array that model line(grid line) that I lose the length constraint. Thus when the grid extends in that direction the lines don't stretch with it. Hope that makes sense.
Huh?  That's how you want to use this sophisticated and expensive BIM software?  To replace grid paper?
Are you wanting a solution or an argument?  I provided the former. I won't provide the latter.
therevitsith
The end result is attached. No argument is intended; I am just trying to reach a shared understanding. Thank you for the solution and for looking it over.
You are welcome.  Thank you for the "thank you".
