I have a project where model lines are snapping to an angle that is 35 deg. from project north. For example, when I try to draw a rectangle model line, it draws it on the shown angle automatically. I have reset the Project North to True North relationship and this is still happening. It does not happen in other templates, for example the Imperial Construction Template. Can anyone tell me how to fix this in my template?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Project North and True North have nothing to do with this.
Turn on Work Plane to see its rotation. You can rotate the Work Plane to the upright angle, or choose the Associated level as the Work Plane to reset it.
Assigning a work plane does fix it, though I turned on the work plane and I don't think it was ever rotated to begin with. So I'm still not sure why it was drawing on an angle.
