Model in Place with Revit LT?
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
BillAllenSE
2166 Aufrufe, 10 Antworten
Can I do this in LT? I can only find "Place a Component".
TIA
10 ANTWORTEN 10
Nachricht 2 von 11
mauricio_mssf
als Antwort auf: BillAllenSE
This is not a function of REVIT LT, for that you would have to upgrade to a full version.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Nachricht 3 von 11
BillAllenSE
als Antwort auf: mauricio_mssf
Thank you.
Nachricht 4 von 11
nmarcelis
@BillAllenSE
You can check with features each flavour of Revit has on this page.
https://www.autodesk.eu/compare/compare-features/revit-vs-revit-lt
If this helped you please accept this as a solution
Revit Certified Professional Architecture, Structure and MEP.
Nachricht 5 von 11
"Place a Component" is not "Model In Place". You can definitely Place a Component in LT.
Understand that the workaround to Model In Place is to Model a Family in a Family Template and load it into the Project.
Nachricht 6 von 11
nmarcelis
als Antwort auf: barthbradley
@barthbradley
This is technically not OPs question
But you are correct, a workaround is to simply create a family.
Nachricht 7 von 11
BillAllenSE
That's not a workaround for a sweep.
Thank you anyway.
Nachricht 8 von 11
als Antwort auf: nmarcelis
@nmarcelis wrote:
@barthbradley
So, basically what you are saying is that I'm wrong AND right. Would you say I'm more right than wrong? Or, am I more wrong than right?  Or, am I equally right and wrong?
Just being silly.  Cheers.
Nachricht 9 von 11
BillAllenSE
Yes!
:leicht_lächelndes_Gesicht:
Thank you.
Nachricht 10 von 11
Nachricht 11 von 11
ejkearney22879
It a bummer you cant model in place, but I guess it has to have it's limitations.  Making you own family instead of model in place is something I will definitely try.
