Model in place void
7 ANTWORTEN 7
Nachricht 1 von 8
mikeferne
450 Aufrufe, 7 Antworten
Model in place void
I created a model in place void in the "New Construction" phase for a knock through but when I switch to "existing" phase the void is also showing. Any ideas?
7 ANTWORTEN 7
Nachricht 2 von 8
vitorbortoncello
als Antwort auf: mikeferne
Check your Phase Filters:
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 8
It's the drawback of using model in place. Create a family if you want it to phase properly.
Nachricht 4 von 8
mikeferne
als Antwort auf: vitorbortoncello
Phase filters are all correct
Nachricht 5 von 8
mikeferne
als Antwort auf: ToanDN
But surly if its created in the new construction phase it shouldn't show in the existing phase?
How else should you phase a knock through?
Nachricht 6 von 8
Post the RVT File so we can participate without the guesswork.
Nachricht 7 von 8
Nachricht 8 von 8
handjonathan
Hi @mikeferne
Thanks a lot for posting your question to the forums!   Has the solution suggested by @vitorbortoncello @ToanDN @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
