A small cornice detail, I can annotate section 1 not section 2. The profile working plane for the sweep not align with section 2. Any way can work on section 2 to add dims and detail lines?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Make the cornice as a part can solve the issue and annotate the detail accordingly. Interesting though, if I changed the model-in place category from generic to lighting fixtures, I can cut in place and annotate in place. But the cut section is incorrect, it has been projected vertically not the real place being cut. Below is the two family category/parameters, not seeing much difference, how could this happen?
