model groups and phasing
4 ANTWORTEN 4
Nachricht 1 von 5
ar00302
364 Aufrufe, 4 Antworten
Hello.
I have made a model group in Revit where the including elements are in different phases.
The problem is when I copy the group all elements moved to the current phase. Is there a way to copy the group maintaining the original phases of elements?
Thank you.
4 ANTWORTEN 4
Nachricht 2 von 5
syman2000
als Antwort auf: ar00302
Group is very sensitive to phasing. One way to do this is create the same floor plan with different phase. If you want to copy your group for the original phase, open up the floor plan for that phase.
Nachricht 3 von 5
ar00302
als Antwort auf: syman2000
The elements inside the group are in different phases. More than one.
Nachricht 4 von 5
syman2000
Ouch....this will be difficult to manage. Typically I would set different group for different phase so they don't cross one with another. This method may require dynamo to achieve what you want.
https://forum.dynamobim.com/t/changing-phase-created-parameter/5026/2
Nachricht 5 von 5
Convert the group to a Revit link, assign phases to elements in that link file, and use a proper phase mapping.
