Model Group Origin
5 ANTWORTEN 5
Nachricht 1 von 6
Kev_D
532 Aufrufe, 5 Antworten
Model Group Origin
I am creating a Model Group for a Condo floor plan layout. I model the elements and create group. Why is the Model Origin 2 levels below, which makes it reference a different level?
I can select it and move it up but the reference level still does not change? Why would the origin be so low?
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Kev_D
The Group Origin has nothing to do with the Ref. Level.
Nachricht 3 von 6
Kev_D
als Antwort auf: barthbradley
Weird, cause that is the level it is referencing. Any idea as to why the reference level is below the placement level. I have ungrouped and regrouped and looked for any hidden elements that could be affecting it, but no joy.
Nachricht 4 von 6
cbcarch
Maybe the Group was initially created on the lower Level, then Copied up to the current Level--and the Group Origin stayed at the original/lower Level?
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 5 von 6
Kev_D
als Antwort auf: cbcarch
@cbcarch
Thanks, but I thought that too. I ungrouped everything and selected only those elements on that level and created the group, but the reference stays 2 levels below.
Nachricht 6 von 6
I'm not sure I understand the issue.  Are you saying that when you group Walls the Group Origin is placed at a Level  below the Walls?  Are the Walls' Base Constraint located at a Level below the bottom of the Walls?  In other words, are the Walls are Offset from their Base Constraint Level?
