Hi all,
Recently I have came across this issue as my Model Group which is used to group all my Grid lines are appearing ungrouped in certain views and I'm unable to select and even the model group. However, on other views they seems grouped properly and I'm able to select and edit the group.
Please help, as I'm unsure how to describe the issue properly please refer to the attached snapshots for further clarification, I can't really find any solutions anywhere else. Thanks!
For the instance below on the "Main View" the Model group seems as a whole, but when I go to it's "Dependent view" they are displaying it as individual and I'm unable to edit anything 2D/ 3D wise.
Views with issue mentioned
Views that are displaying correctly
Do you see Edit Group from the ribbon when select an individual grid within the group? If so, just edit and modify 2d extent if need be.
Grouping grids is tricky. Did you create the group from a cropped view with grids displayed with 2d extent? I would create the group from an uncropped view, with grids displayed with the actual 3d extent.
