Model Group containing In-Place voids do not move in height when pasted into a project
1 ANTWORT 1
Nachricht 1 von 2
adimariaBXE2A
156 Aufrufe, 1 Antwort
I have created an architectural wall containing In-Place generic model voids in a project file.
I would need to use the same geometry a few times with light changes to each of them: for this I have tried several workflow such as pasting the geometry or creating a model group, then copy the model group into the new project, ungroup and move it into position (it worked once with a different model group) but I have issue with this. The In-place void do not move in z-direction.
Could you help with any workflow to avoid modelling again ?
1 ANTWORT 1
Nachricht 2 von 2
ralphdenhaan
als Antwort auf: adimariaBXE2A
I think the safest way to make voids is by creating a "Void Family" (generic model family e.g.). You can simply add them to groups and they act the same way even when groups are mirrored for example.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
