Hello I have been using Revit 2019 for few years now, just upgraded to Revit LT 22. I have upgraded my template which works fine apart from when i put in realistic mode my model instead displays as wireframe? is this a material issue?
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Did you install the Update?
...or do you mean this?
Hi guys so i have done the update buts its still not working. Its not just 3D views its also elevations views example below. It displays fine in all the view modes apart from realistic I've tried multiple models some upgraded from 2019 some created from scratch in 2022. I have checked the materials still have the photo texture with it and they do. Out of ideas
@Anonymous
Try the either of following
Unload/switch off any unnecessary CAD links
