Model Display / transparency not correct
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
micah
4550 Aufrufe, 11 Antworten
My new Revit project is acting up and I cannot figure out what is wrong. The floor plan view is showing as Wire Frame/transparent, even though the template's Model Display is set to Hidden Line. I have checked overrides and see no conflicts there. Any ideas?
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: micah
Does the View Template actually control the Model Display (is the box checked)?
Nachricht 3 von 12
micah
als Antwort auf: ToanDN
Yes, it is checked. Transparency settings are all set to 0 also.
Nachricht 4 von 12
Well, maybe just change the view to non-template and fix the model display to hidden lines. Then change it back to the template see if it sticks.
Nachricht 5 von 12
Richard.Vivanco
What about the material? assign a different material.
Good luck
Richard Vivanco V.
Arq. BIM Manager + Autodesk Certified Instructor
Website | Youtube | LinkedIn
Nachricht 6 von 12
micah
I tried that, thank you, but it didn't work. I also changed view depth from unlimited to associated level. This helped hide most of the stem walls but a few are still visible. I checked the sections and I don't see any difference between those that are now hidden and those that are still visible. Also the toilet is still transparent, for example, so I know it is not just a material transparency.
Nachricht 7 von 12
micah
als Antwort auf: Richard.Vivanco
Hi, materials are all transparent so it is not related to that.
Thanks though for the suggestion.
Nachricht 8 von 12
micah
I am finding that my existing floor plan displays transparent even when I change view templates. However my proposed and schematic floor plans correctly show no transparency even when I change view templates. If I try to create a new floor plan based on my correctly displayed proposed floor plan the new plan is showing transparent. Can someone please help? I am wasting a whole afternoon spinning my wheels and I need to get this project moving.
Nachricht 9 von 12
micah
I am narrowing this issue down to a linked topo cad file. My trouble shooting process was as follows:
I have found that if I duplicated my proposed floor plan (which is correctly showing no transparency as expected) and then change the view template to my existing floor plan template (my existing floor plan is the one with the transparency issue) the transparency is gone and the display is correct. In other words duplicating the good floor plan apparently fixed the issue.
However if I un-check Crop View from any of my floor plans, regardless of view template, the transparency issue reappears. The crop view toggle turns this transparency issue on and off.
Finally, if I go to Manage Links and remove the topo CAD file from the project the issue seems completely resolved in all views and view templates, cropped or un-cropped. As a further test, with the apparently problematic topo removed, I linked another topo file from the same surveyor. No issue with this topo from another project. I tried auditing and purging the problematic CAD topo file and the issue persists. However when I cut/paste the problematic topo linework and other graphic elements into the good topo file I have from another project and insert that topo, the issue is resolved. There must be something corrupt in the topo cad file and I'll have to ask the surveyor to fix it. I can't just use the topo I fixed because the coordinates, etc. are for the other project.
So, I think I resolved this and am sharing all of the above as a lesson in trouble-shooting. I hope this helps others and may lead to an explanation or better fix from Autodesk.
Again, thank you to all contributors on this forum and this post thread.
Nachricht 10 von 12
micah
Hi Richard,
Thank you for your suggestion. I think I solved it. If interested please see my solution above in this thread.
Nachricht 11 von 12
micah
Hi ToanDN,
Thank you for your suggestions. I think I solved it. If interested please see my solution above in this thread.
Nachricht 12 von 12
Open "Edit Family", Click on the solid component mass, in the properties bar edit "Visibility/Graphics", select "Plan/RCP", "Ok", save the component and reload into project.
Simple explanation: The component mass model was set to show in elevation view and not plan view. The initial plan view only shows detail lines and not the mass, hence the reason why it is transparent.
